Menu not opening on mobile
    I am using GeneratePress and the off canvas menu on my website stopped showing up suddenly.
    I found the issue is being caused by LiteSpeed cache, specifically the Load JS Deferred setting.
    If the Load JS Deferred is turned off, the menu displays correctly, if it is Deferred or Delayed, then the menu doesn’t show up.
    I do not want to turn this setting off completely due to performance reasons, can you suggest a work around for this issue?
    you would need to tell Litespeed to not mess with that file. It should have some exclusion fields in it settings.
    The script name of the off canvas panel is: offside.min.js
    But you may need to check with Litespeed support how to exclude it
