SamuelJS
I want the menu right next to the new search function and not centered. How do I have to set this? Or can it be that a custom code produces this?
Hi Samuel,
Can you provide the link to the site in question?
SamuelJS
Soory, sure
Try adding this through Appearance > Customize > Additional CSS:
div#primary-menu { order: 1; } -
SamuelJS
I misspoke, I don’t want to change the order but reduce the distance. So the menu elements should be further to the right of the search field.
can you share a link to the site ?
SamuelJS
Hi David, it’s in the Private information section 🙂
SamuelJS
Any Updates here?
Hi Sam,
I’m not seeing a private info section attached to your post – I don’t believe this is a bug on our end.
Can you confirm?
SamuelJS
very funny. i am 100% sure that i had deposited something there. Can it be that the new forum deletes this info over time?
Anyway, the infos are now back in…
Can you try this instead?:
.header-wrap .inside-navigation.grid-container { justify-content: flex-start; } .header-wrap .inside-navigation.grid-container .site-logo { margin-right: auto; } -
SamuelJS
Love it. Thanks, Fernando.
Any forward perspective that we can eventually style our main navigation with gen blocks?
You’re welcome, Samuel!
Well, for now, to alter the Header fully through GB, you’d need a Block Element – Site Header through GPP.
Another route is to use a Block Element – Hook.
