Meta Box AIO WYSIWYG Field
    I created an FAQ CPT with these fields:
    1. Question: Post Title
    2. Answer: WYSIWYG Field (id: answer)
    Then, I add a Query Loop for FAQ posts with an Accordion Field for Questions and Answers. In the Answer I add Text field and set dynamic data to Post Meta -> Meta Key: answer. The result is blank.
    What is the correct way to do this?
    Screenshot: https://live.staticflickr.com/65535/54891223742_7656b3df44_c.jpg
    Thank you
    Best regards,
    Kawan
  • Hi Kawan,
    Yes, it should work.
    Can you show me your dynamic tag for the answer?
    Or can you provide an admin login so I can see the setup in the backend?
