Missing images in search results
    I have the issue that when searching something on my blog only the first image is shown but the rest is missing. I never had this before. Maybe you can take a look?
    Greetings Kathrin
    I do not see this issue:
    https://app.screencast.com/PguySKwfIhaa4
    All images are loaded correctly.
  • Strange. I also have that issue on my smartphone. Is there a way for me to debug it?
  • This time when I check, the images are not showing, except for the 1st image.
    To debug, please disable all plugins, if that issue is gone, then re-enable plugins one at a time to see which one is causing the issue.
    If you are using a child theme, then switch to the parent theme to eliminate the custom function causing the issue.
