I’m using Generate Press premium /GP block editor with WordPress (block editor), and on some of my pages I can no longer see the layout options panel — specifically the ability to:
Hide the page title
Switch layout to full-width
Disable elements like header/footer
I’ve checked the following already:
✅ I’m using the Gutenberg block editor (not classic)
✅ I’m logged in as Administrator
✅ GP Premium is installed and activated
✅ The “Disable Elements” module is enabled✅ I checked the bottom of the editor to see if the layout metabox was moved there — still not visible
I also made sure caching isn’t the issue and tried a fresh test page, but the controls are still missing.
My theme and plugin versions are up to date.
Any known bugs or conflicts?
I saw other users mention similar issues in the past. Could this be caused by:
A conflict with a recent WordPress update?
The block editor UI changing how metaboxes are displayed?
Some invisible meta setting that disables the layout panel for certain pages?
Any help would be appreciated. Let me know if you need admin access or debug info.
Thanks in advance!
The password is incorrect. I can not log in to your site.
Can you check if the layout metabox is at the bottom of the editor?
Hello Ying,
Thank you for your response. I updated the password and tested. You can log in now.
The issue is fixed now! I dont know what happened but it’s no longer there!
Glad to hear that 🙂
