honzapecenka
Hi, I have an interesting problem. The hovered links selector is missing from my settings. I have added text with a link, but the selector is not displayed. Interestingly, when I copy identical text from another website and set it up in exactly the same way, the hovered links are displayed.
How is this possible? -
I’m unable to reproduce the issue. Are you running the latest version of GenerateBlocks?
Also, try temporarily deactivating all plugins except GenerateBlocks, then add the Text block again to see if the issue persists. This will help rule out a potential plugin conflict.
Let me know how it goes!
honzapecenka
Already solved. I had set the font color on the parent container. To edit the link and hover, I had to change it on the nested container where the link is located.
Thanks. -
Glad to hear that 🙂
