Mobile block not responsive
    I have a reusable block on my site that is not responsive. All other containers have been responsive with no problems. It’s across all pages.
    Here is an example: https://printablesforlife.com/wide-ruled-paper/
    Should I re-create he container? I’d hate to have to do it for all posts… If there is something simple that I’m missing, let me know 😀
  • I think it might be related to the GIFs. I’m not sure that they are responsive by default like regular pictures set to “auto.” If not, is there a way to make this happen?
    Could you specify which block you’re referring to as not responsive? I’ve reviewed the page you shared, and from my perspective, all parts appear to be responsive.
  • It’s the “Get Printable” container. Some parts seem responsive and others don’t.
    I’m not sure if I can add a screenshot here to show you what I see on my end?
  • Okay, I see it now. Could you try removing any padding that was set in the container?
  • I’m trying to remove padding and margins, but I’m having a lot of trouble with the plugin.
    Example:
    1) I cannot right-click and “select container” to select the outer elements of multiple inner containers.
    2) Colors have disappeared as an option.
    3) Even when I delete padding and margins, they are still present in light grey unless I set the margins and padding to 0, but that also affects the layout.
    I’ve tried clearing the cache for my browser and the site.
    Should I uninstall and reinstall the plugin?
    Any advice would be appreciated!
  • Here’s my login info if you want to take a look.
    I’m also okay if you want to handle the uninstall/reinstall to make sure it’s done as cleanly as possible.
    Thanks 😀
  • The parent container is set to display:flex, can you change that to default?
  • I changed it back. You’ll see that parts are still not responsive. It also doesn’t fix me not being able to add/change colors (option is not on menu).
  • It seems responsive to me:
    https://app.screencast.com/c9mJAwNtNIr0t
    I’m not sure I understand the issue, the display property does not interfere with colors at all. Don’t see the connection between those two. Can you explain some more?
  • You’re right, I was able to fix the responsiveness, but I had to uninstall and reinstall the plugins and then rebuild the block entirely and update each page manually. It seems to have fixed all of the problems.
    To summarize:
    1. The container wasn’t being responsive in all areas.
    2. Upon investigation, I realized other attributes were missing (like color, margin, and padding) from the appearance menu.
    3. To fix this, I uninstalled and reinstalled the plugin, deleted the original block, and started from scratch.
    Luckily, I only had about 15 posts affected.
  • Glad you got it to work!
