rawhasan
Something is breaking the mobile layout on this page (enabling right scroll), while the other pages using the same template are working fine.
How can I fix this?
1. select the 1st grid block gb-element-ed8a58d1, set grid-column-template to 100% on mobile instead of 1fr.
2. The gallery container gb-element-7ef10690 ( rh-custom-gallery full-width )has width set to 100vw, which is exceeding its parent element’s width, try setting its max-width to 100% instead of 768px on mobile.
rawhasan
Thanks for pointing out the block that is was breaking out the mobile layout.
Keeping everything the same and just adding a
-20pxleft and right margin for the mobile fixed the issue. -
