Mobile Layout not Pulling CSS through
    I’m using some of the new GB Patterns (as a pro user on both GB and GP) to restyle my home page at https://thisisplanetpatrick.com – I’m also using the new Global Styles, which I much prefer to the old version – thanks for that!
    When I started testing the new home page style, the preview in Safari, Chrome and Opera (using a MacOS and iPadOS) was off, so I cleared the cache at host level (Siteground) and now the site looks correct.
    However, for mobile, there’s a big difference between what I’m seeing in the Customiser mobile preview and on a test iPhone using Safari, Chrome and Opera.
    Is this still a caching issue, or am I missing something obvious? I’m sharing the Customiser view and the site as seen on iPhone Safari as images in the private section below so you can see that the styling and layout is not pulling through.
    Thanks for any suggestions,
    Patrick
    Can you disable all caching to test first?
  • Hi Leo,
    If I add ?nocache to the end of the URL on mobile, it DOES pull through the correct layout/styling. So that’s good news.
    Having cleared the cache at host level (I’m with Siteground), I went through any plugin with a cache feature – in the end the culprit was WP Rocket. Sharing that here in case it helps anyone else.
    Thank you very much!
  • No problem 🙂
