john hogan
I have a mobile stacked logo that is not showing on the main menu but does show on the sticky menu. I would like it to show on the top main menu on the right – just like the sticky menu.
Link is in private info.
Hi John,
Are you using a header element which has a logo uploaded?
Can you check and let me know!
john hogan
I am not. I am using the customization on the GP area.
I have put the element code for the phone and the appointment button on the main menu
Hum…that’s weird, I’m seeing some page hero related code on your site.
Any chance you can provide an admin login so I can check the backend?
john hogan
Here is admin access
So yes, you do have a header element with logo uploaded there:
https://app.screencast.com/uWx2s3cNgtbq2Try removing the mobile header logo to see if that helps.
john hogan
I have removed it and it does not work.
Under Customize > Layout > Primary Navigation, the Menu Item Height value for the mobile breakpoint is currently empty: https://cln.sh/nhsc0KPd6Hw40tzSq94C
Try setting it to
60pxto match the height of the mobile sticky navigation logo. -
john hogan
thank you
You’re welcome!
