Mobile menu behind header content
    My mobile menu is appearing behind one of the blocks of text on my hero section. I’ve checked the Z index but it doesn’t have a value. I tried setting it to 0 but this didn’t help.
    What do you think the problem could be?
    Select the Testimonial block, switch to mobile view editing first, and then check the z-index value. It is currently set to 10—simply removing it should fix the issue.
  • Thank you very much!
  • You’re welcome!
