YEAR93
I’m currently working on a mobile navigation setup and I’m experiencing an issue with the mobile menu behavior.
When the menu toggle is opened on mobile, the navigation expands and pushes the page content down instead of behaving like an overlay.
Ideally, I want the mobile menu to:
- Open as an overlay (or fixed layer) without the Off-canvas panel enabled
- Not affect the page layout height
- Not push any content down when toggled
- Keep the header height stable
At the moment, the .main-navigation (or .main-nav) appears to be expanding in height and affecting the page flow when toggled, which causes the page shift down.
Could you please advise the recommended GeneratePress way to:
- Convert the mobile menu into an overlay/fixed navigation
- Prevent layout shifting when the menu is opened
I want to ensure I’m using the correct GeneratePress structure instead of relying on heavy custom CSS that might conflict with the theme.
Thank you for your help.
George
Remove
height: calc(100vh - 72px);from this CSS:.main-navigation.toggled .main-nav { height: calc(100vh - 72px); overflow-y: auto; opacity: 0; transform: translateY(12px); animation: menuIn 0.35s ease forwards; }Prevent layout shifting when the menu is opened
Remove
height: 100%;from this CSS:.main-navigation.toggled .main-nav ul { height: 100%; display: flex; flex-direction: column; justify-content: flex-end; } -
YEAR93
I think you misunderstood my issue a bit.
I’m not only trying to adjust the height or animations of the mobile menu the main problem is that the mobile navigation is currently affecting the page flow.
When the menu is toggled,
.main-navigationis expanding in height and pushing the page content down. What I’m trying to achieve is an overlay / fixed-style mobile menu that does not impact layout height at all.So removing or adjusting
height: calc(100vh - 72px)andheight: 100%only changes how it looks after it has already taken space in the layout but it doesn’t solve the underlying issue of the menu still being in-flow.What I’m looking for is the recommended approach to make the mobile menu behave like an overlay (position fixed/absolute).
Thanks again.
You can set
#site-navigation.toggled‘spositiontofixed, so it won’t affect other elements. -
YEAR93
I’ve made a screen recording so you check what happens when I add position: fixed; to #site-navigation.toggled
That seems normal to me; you can set its background color to white.
YEAR93
Thank you for clarifying.
However, the styling of the navigation menu itself looks quite different in the toggled state compared when
position: fixed;is added to how it was before (check screen recording).At the moment once the menu becomes fixed/toggled, the layout/spacing and overall visual styling no longer match.
I could add something like this, but that doesn’t really solve everything:
#site-navigation.toggled { margin-top: 0; position: fixed; background: rgba(255, 255, 255, 0.8); top: 72px; width: 100%; height: 100vh; backdrop-filter: blur(12px); -webkit-backdrop-filter: blur(12px); transition: all 0.3s ease; } .main-navigation.toggled .main-nav ul { padding-bottom: 20px; }What I’m seeing now is that when this state is active, the menu styling (spacing, alignment, and overall structure) differs significantly from the original navigation style, making it look inconsistent.
It seems like the fixed/toggled state is either overriding or changing how the base navigation styles are applied.
Could you check if the toggled state needs additional styling overrides so the menu retains the same visual structure as before, just in overlay/fixed mode?
George
The only difference I see as far as styles are concerned is the size of the font which is handled by this CSS:
@media (max-width: 768px) { .main-navigation.toggled .main-nav li > a { font-size: 40px; line-height: 1.2em; padding: 0; } } -
YEAR93
Got it.
I had to set the
.site-headertoposition: fixedto prevent it from affecting the mobile navigation layout and causing the push/shift issue..site-header { position: fixed; width: 100%; }This resolves the layout shift on mobile.
I also noticed the body content now sits underneath the header since it’s set to
position: fixed.Should I add the following to compensate for the header height on mobile?
body { padding-top: 72px; }72pxis the height of the fixed header on mobile. -
George
You can add
top: 72pxto your.site-headerdeclaration. -
YEAR93
I tried that solution (see screen recording), but it doesn’t resolve the issue correctly.
Adding
top: 72pxto.site-headercauses the header to go down and doesn’t prevent the content from being underneath the header or properly account for the fixed header height.Could you please advise on the correct recommended approach for handling a fixed mobile header in GeneratePress without causing content overlap/shift?
George
Just want to be absolutely clear of what you are trying to achieve here. You want to be able to click the hamburger menu and have the menu open while users scroll down the page on mobile, correct?
Menu will close when user clicks the Close X icon. Have you thought about the usability of this method especially in smaller phones?
YEAR93
No, that issue is already resolved by adding
position: fixedto the.site-header.However, doing so causes the page content to sit underneath the header. On mobile,
the .site-headerhas aheightof72px, so I have currently addedpadding-top: 72pxto the body to offset the content and bring it back into the correct position.My question was whether this is the recommended approach in GeneratePress, or if there is a better and more reliable way to handle this situation. View screen recording 2 for reference.
Also, could you please remove the screenshot of my staging website from your previous reply? That environment is still under development and not intended for public viewing. Sharing or referencing it publicly may lead to confusion, as the content is not final and may contain incorrect or incomplete information. I would appreciate it if it could be taken down for privacy and staging confidentiality reasons.
To address the spacing issue caused by
position: fixed, you do not need to add paddings; you can simply change it toposition: stickyinstead. -
YEAR93
If I switch to
position: sticky, I run into the same issue I was trying to avoid when I opened this ticket. On mobile, the menu toggle still pushes the page content down, which affects the layout behaviour I’m trying to prevent.That’s why I initially went with
position: fixedand handled the offset manually. Is this the recommended approach in this case, or would you suggest a more robust solution within GeneratePress? -
Yes, this is the way to go.
