techjuyel
I want a mobile menu for my website designed similar to the one on this page:
🔗 https://www.shutterstock.com/blog/instagram-captionsHowever, please exclude the “Login / Signup” buttons and the language selection option that appear at the bottom of the Shutterstock menu.
This menu should appear only in Day mode (not in Dark mode).
In short, I need a clean, responsive, and stylish mobile menu inspired by the link above — but without the login/signup and language options.
Please note that we can’t assist with creating a layout from scratch, as that would fall under custom development and is outside our support scope. However, we’re happy to help if you already have a menu set up and need guidance on how to achieve something specific using our tools.
That said, the example menu you’re referring to would require a custom build. You can still achieve the basic dropdown functionality on click by using the default GeneratePress menu and enabling the Mobile Header option: https://docs.generatepress.com/article/mobile-header/
techjuyel
I can’t do the design I showed you, so I asked you to please complete it so that it can work.
We can not assist with this request; unfortunately, the menu you are referring to requires custom development.
And as Alvind said, we can guide you, but we can not build the layout for you.
techjuyel
So please guide me and give me a complete suggestion on how to do it.
So you need 2 menus on mobile?
You can use both the primary navigation and the secondary navigation, and enable the off-canvas panel for the primary navigation.
And enable the mobile header at customizer > layout > header.
Once it’s done, let us know!
