frifugl
Hi. A question about an article using blocks, where the mobile view looks a bit strange (squeezed paragraph-text).
Image block is on top, but in portrait mode the paragraph below gets very narrow. How to avoid this/fix issue? -
try adding this CSS:
@media(max-width: 600px) { .wp-block-image .alignright { float: none; margin: unset; } } -
frifugl
Hi. Did not make any difference, as far as I can see.
frifugl
Cache issue, actually worked. Is this because of some css-issue on this specific site, or do I need to use this css-addition on all sites using generateblocks?
I see. Glad David’s code worked. This issue is with the WordPress Image Block, not a GenerateBlocks Image Block. If you’re using a WordPress Image Block on the other sites and you’re encountering the same issue, using David’s code should help.
frifugl
Ok. So when adding an image block, the user needs to make sure to make a Generatepress Image block, not a wordpress image block? How do they differ, what instructions should I give to the editors on site to make sure they select the right type?
Yes, using the Image Block from GenerateBlocks is more controllable.
The logo of the GenerateBlocks Image is this: https://share.zight.com/2NuW5XAe
It’s color blue. In comparison, the one from WordPress is black.
