Model Stats
  • How to create a Page with Model Stats on the left and image on the right?
    Kindly check the links.
    It’s pretty easy to build. What you need is a Grid block set to 2 columns.
    In the left column, where the text will go, add an inner container and place all of your text content inside that container.
    In the right column, simply add a GB Image block for the image.
    Once you’ve built that base layout, let me know and I can suggest any further adjustments.
