Modify dynamic data – list of categories
  • I’m trying to do two things:
    1. Use a headline block or similar to list categories in a query loop, but have them separated into separate “pills” where each category looks like a little button with a background color and space between items — so far I have only been able to list them within the same headline block, where the border/margin and so forth surround all of the terms rather than individually.
    2. Relatedly, is there a way to list only the first category assigned to the post, instead of all of them?
    Hope this makes sense, thanks for your help!
  • Hi Marty.
    Let’s address #2 first.
    Can you add the Categories through a Headline Block or a Button Block to your Query Loop? Let’s keep one and hide others through custom CSS.
  • That’s what I’m currently doing. Using a headline block inside a query loop. You can see it at the root URL I shared (it moved to the main front page now) in the right column at the top of the fold.
  • Give the Headline Block a class of hide-other-terms
    Adding Custom Classes: https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/
    Then, add this through Appearance > Customize > Additional CSS:
    .gb-headline.hide-other-terms > :not(:first-child){
        display:none !important;
    Let us know how it goes.
  • I have tried this and placed it along with my CSS to hide the ‘front page’ category:
    .hide-front .gb-headline>.term-frontpage,
    .hide-front .gb-headline-text>.term-frontpage {
        display: none;
    .hide-front .gb-headline.dynamic-term-class>*:not(:last-of-type):after {
        content: " "
    It works, but only for a post that has more than one category. Is there a way to only hide the second or later categories?
    You can currently see this at my URL currently.
  • Added screencap.
  • Is there a way to only hide the second or later categories?
    The CSS is written in this way. The post in the screenshot is displaying correctly in my eyes, can you let me know what is issue with it? 🙂
  • In the second post in the screenshot, there is no category displayed at all (it’s a little blue dot)
    The relevant HTML, both hidden by the CSS:
    <div class="gb-headline gb-headline-8665733c hide-other-terms gb-headline-text wp-dark-mode-ignore"><span class="post-term-item term-frontpage wp-dark-mode-ignore">Front Page</span> <span class="post-term-item term-projects wp-dark-mode-ignore">Projects</span></div>
    In this instance I would still like to display the ‘Projects’ category.
    thanks!
  • It’s hidden because of this CSS:
        display: none;
    You can change it to:
    .hide-front .gb-headline>.term-frontpage:not(:first-child), .hide-front .gb-headline-text>.term-frontpage:not(:first-child) {
        display: none;
  • Hmm, I tried the CSS but now it displays Front Page, which I want to purposely hide intentionally, but I do not want to hide the Project category in my example.
    So I want to show a single category for each post, and I want to hide Front Page. All others are fine to display.
    Hope that makes sense, lmk!
  • Can you remove all the CSS you have for hiding these first? Let’s try to do it from scratch to avoid conflicting codes.
  • Sure. When I tested this earlier I did comment out my previous CSS.
    Basically I need to
    – Hide ‘Front Page’ category
    – Display only one category (curious also how to set the order by of this)
    – Additionally I’m still interested in learning how to display categories in this manner but have separate divs / buttons / containers for each category so they appear as separate shapes.
    Thank you!
  • Can you clear the cache from Autoptimize or temporarily disable it first?
  • Ah yes good catch, I have cleared it now.
  • The previous codes seem to still be there from my end. Can you try disabling caching plugins instead?
  • I restored my previous CSS as the newer CSS was showing the category I wanted to hide. I will attempt this again shortly.
Viewing 16 posts - 1 through 16 (of 17 total)
