modify h2 titles in category pages
  • HI
    I checked the generate_get_the_title_parameters function but I am not able to modify the content of the <h2> tag.
    add_filter( 'generate_get_the_title_parameters', function( $params ) {
        if ( ! is_singular() ) {
            $params = array(
                'before' => sprintf(
                    '<h3 class="entry-title"%2$s><a href="%1$s" rel="bookmark">',
                    esc_url( get_permalink() ),
                   'microdata' === generate_get_schema_type() ? ' itemprop="headline"' : ''
                'after' => '</a></h3>',
        return $params;
    Is there any function/hook that would allow me to modify the h2 tag on the archive pages? I can’t figure out how to use the function to modify the title output.
    What is your goal? To change the h2s on archives to h3?
  • Hello
    My goal is to modify the content inside <h2></h2>. To modify the post titles on category page.
    Could you link me to one of the archive pages?
  • I can’t share my website publicly but I’m showing the html structure
    so in my site there is a category /category/recipes/
    in there the post titles are displayed as such<
    null
    <article id="post-569182" class="post-569182 post type-post status-publish format-standard hentry category-recipes">
    	<div class="inside-article">
    		<header class="entry-header">
    			<h2 class="entry-title"><a href="link-to-recipe/" rel="bookmark">RECIPE TITLE LONG</a></h2>
    			<div class="entry-meta">
    				<span class="posted-on"><time class="entry-date published" datetime="2024-10-31T14:30:21+00:00">October 31, 2024</time></span>
    			</div>
    		</header>
    		<div class="entry-content">
    			<p><b>This is a recipe for...</b>.</p>
    		</div>
    	</div>
    </article>
    So I want to be able to change the content of the <h2> tag from
    to
    <h2 class="entry-title"><a href="link-to-recipe/" rel="bookmark">RECIPE MODIFIED</a></h2>
  • Do you want to change this one specific post title?
    I do not understand, why not just change the post title directly?
  • I want to shorten some post titles on the paginated pages but I want the full titles on single posts.
    Can I modify the appearance of the <h2> titles on the paginated pages?
  • what do you mean by shortening, like how?
    Something like limiting the title length to 5 words?
  • Hi
    As I explained
    <h2 class=”entry-title”>RECIPE TITLE LONG</h2>
    to
    <h2 class=”entry-title”>RECIPE MODIFIED</h2>
    I want to be able to modify the title tag, only on the category/paginated page. Not in the post itself.
    where would the modified text come from ? eg. a Custom Field ?
  • Hi David
    I want to intercept the loop in the paginated page. I simply want to replace or explode and then display part of the title as its fetched from the db.
    Can I do that?
  • The template simply uses the get_the_title() function to display the title.
    And you can filter the title content with the the_title hook:
    https://developer.wordpress.org/reference/hooks/the_title/
    For example:
    function my_archive_title_filter($title, $id = null) {
        // Check if we are in an archive and within the main query loop
        if (is_archive() && in_the_loop() && is_main_query()) {
            // Modify the title as needed for archive pages
            $title = 'Archive: ' . $title;
        return $title;
    add_filter('the_title', 'my_archive_title_filter', 10, 2);
  • Hello David
    I don’t mean the h1 archive title. I mean to intercept the content of the h2 titles on the category paginated page.
  • What you provided modifies the header title of the paginated page I want to change
    <h2>Cocktail 1 Long title</h2>
    excerpt
    <h2>Cocktail 2 Long title</h2>
    excerpt
    <h2>Cocktail 3 Long title</h2>
    excerpt
    to maybe be able to display them as
    <h2>Cocktail 1</h2>
    excerpt
    <h2>Cocktail 2</h2>
    excerpt
    <h2>Cocktail 3</h2>
    excerpt
    I hope I am more clear now.
  • David’s code is for the h2 titles on the archive page. you can add is_paged() condition as well.
    As for how to shorten the title, you need to write your own logic.
        if (is_archive() && in_the_loop() && is_main_query() && is_paged()) {
            //Write your own logic to shorten the title
        return $title;
  • Thanks
    Finally the answer I needed. There is no hook for this.
Viewing 16 posts - 1 through 16 (of 17 total)
