more fonts loading?
    In my generatepress customiser I believe I have two fonts selected (raleway and lato), however, I see in GT metrix that four fonts are loading on a page.
    Do you know where these other fonts may be coming from?
    Thanks in advance
    What are the other 2 fonts?
    I’m not quite sure that’s the issue! I was discussing this with the support at perfmatters and was asking them why are there 4 fonts loading in GT metrix, and he said it must be picking up the fonts from generatepress or a pagebuilder.
    I’ve put a link to the screenshot of GT metrix picking up the woff files and the links of the files. It doesn’t say the name of the font though.
    It’s possible that a certain plugin you installed is loading its own font, as we’ve seen in other cases with users. If you temporarily deactivate Perfmatters and rerun the GT Metrix diagnostics, does the font still load?
    So I ran the test without perfmatters and it shows that there are three lato’s for some reason and one raleway loading.
    I’ll attach the screenshot.
  • Can you keep the cache/performance plugin disabled so we can see the issue more clearly?
  • ok, i’ve now disabled it.
    I see that you are adding Raleway and Lato in the customizer.
    The Roboto font is requested by AMP, and Sans font is requested by Ads.
    To reduce font request for the 2 fonts added to the customizer, go to customizer > typography, edit the font’s variants, only keep the font-weight that you are actually using, and remove the rest of them to stop sending request for each font weight.
    For the other two fonts, you might need to reach out to the plugin’s support.
