2jamgen
So do we have to recreate the local libraries we had from before, or somehow import them to the new library? I see no checkbox for Local Library under “Manage Libraries” and so are these to be created in the Appearance > Patterns or what is equal to GenerateBlocks > Local Patters?
It would seem that a way to migrate these would be in the instructions for this before going live. I may have missed that, but see no documentation on this, just a guessing game.
There is no need to re-create your existing local patterns, and you can still access them in GenerateBlocks > Patterns > Legacy Patterns.
Users can continue to use them and access them in the same way for the foreseeable future.
2jamgen
Yes, it is true that it can be accessed, so to be clear what I am needing is to add the older Patterns to the New Pattern Library as “local” patterns.
The only way I see it is possible to do is to manually copy the block or older pattern elements, then create a new pattern in the New Pattern Library. Is that the only way, or is there a way to export and then import to the new?
Yes, you will need to manually do the transfer work, unforturnaly.
The new patterns are using WP patterns, while the legacy one is another custom post type.
2jamgen
Thanks for the answer. Makes sense to go with the native system and piggy back on that.
