chimpanzee01
I’ve managed to get a progress bar working well on two websites with the following code and the wp_head hook. I can’t seem to get the progress bar to be at the bottom of the sticky navigation menu. Right now it’s at the top of the menu when scrolling.
Reading Progress Bar CSS
<style> .header { position: fixed; top: 0; z-index: 1; width: 100%; background-color: #f1f1f1; } .progress-container { width: 100%; height: 5px; background: #ccc; } .progress-bar { height: 5px; background: #b39294; width: 0%; } .top-bar { position: -webkit-sticky; position: sticky; top: 0; z-index: 100; } .nav-float-right .is_stuck.main-navigation:not(.toggled) { top: 5px !important; } </style>
Reading Progress Bar HTML
<div class="header"> <div class="progress-container"> <div class="progress-bar" id="myBar"> </div> </div> </div>
Reading Progress Bar JavaScript
<script> // When the user scrolls the page, execute myFunction window.onscroll = function() {myFunction()}; function myFunction() { var winScroll = document.body.scrollTop || document.documentElement.scrollTop; var height = document.documentElement.scrollHeight - document.documentElement.clientHeight; var scrolled = (winScroll / height) * 100; document.getElementById("myBar").style.width = scrolled + "%"; } </script>
1. Use
generate_before_header
hook for the bar.2. Disable GP’s sticky navigation in the customizer.
3. Add this CSS:
.header-wrap { display: flex; flex-direction: column; position: sticky; top:0; } .site-header { order: -1; }
chimpanzee01
I tried this but the sticky navigation doesn’t show up with the CSS. I’d like the sticky navigation with the progress bar at the bottom of the sticky navigation. I wonder if the CSS you provided needs a tweak or two.
your current function hooks the progress bar above the header, and it needs to be attached to the sticky nav.
Remove the current HTML, CSS and Script you have for the progress bar.Enable the GP Sticky navigation.
Add this Script:
<script> window.onscroll = function() {updateScrollPercentage()}; function updateScrollPercentage() { var winScroll = document.body.scrollTop || document.documentElement.scrollTop; var height = document.documentElement.scrollHeight - document.documentElement.clientHeight; var scrolled = (winScroll / height) * 100; // Set CSS variable document.documentElement.style.setProperty('--scroll-percentage', scrolled + '%'); } </script>
and this style:
<style> :root { --scroll-percentage: 0; /* Default value */ } .navigation-stick .inside-navigation { position: relative; } .navigation-stick .inside-navigation:after { content: ''; pointer-events: none; position: absolute; left: 0; bottom: 0; height: 4px; width: var(--scroll-percentage); background-color: #0092FF; } </style>
Its a pure CSS method that will add the line to the sticky navigation only.
chimpanzee01
Thank you. This is resolved!
Glad to hear that!
chimpanzee01
Is there a way to create CSS to add exceptions to the sticky navigation menu (disable it) for certain pages?
A simple way would be this CSS:
body:is(.page-id-77, .page-id-75 ) #mobile-header.navigation-stick{ display: none !important; }
Note here:
It includes the page-id-XX for the specific pages. You can comma separate more IDs if you need.
Note here:
chimpanzee01
Ok thank you!
You’re welcome
