my changes do not update
  • Hi i am trying to design the home page in generate press and whatever changes i am doing it doesnt show or refesh them. i. have. a different picture but it still shows the ols one etc.
    what can i do to make the changes show?
    Thank you
    Sounds like a caching plugin issue.
    Please make sure all caching and optimization plugins and server caching are cleared and disabled.
    If that doesn’t help then try #1 here to debug: https://docs.generatepress.com/article/debugging-tips/
    Let me know if this helps 🙂
  • how do the caching and optimization pluggings clearing? i am sorry i am new to this.
    thank you
    Do you have any caching plugins installed? Just deactivate them and proceed to make changes to your page. See if the issue persists.
  • i have breeze is that a cashing plugging?
  • the problem still presits i am unable to see any changes
  • Can you link us to the page in question with all plugins disabled?
  • how can i do that?
    you mean the login access?
  • Please edit your first post on this topic, and add the site login info into the private info field. It will only be seen by the support team 🙂
    Please make sure all plugins are deactivated.
  • sure i am giving the info now
    thank you
  • is my homepage that is not updating not the post
  • Let me know when you’ve finished editing the homepage. I can’t access the editor while you’re working on it.
  • Ready now
  • If you’re referring to the content in the hero section, it is not visible on the frontend because it’s covered by the background image. To make it visible, wrap the content inside a container and set its z-index to 99 under the Layout setting.
  • ok thank you i will try it now and let you know
  • thank you it worked. Before i deactived the pluggin even the photo wasnt updating. now that i deactived the pluggins it is updating.
    my question is cannot i not use the pluggins now?
    or do i wait until i design my page and then activate them again.
    What is the procedure?
    thank you
Viewing 16 posts - 1 through 16 (of 17 total)
