I have this custom css:
#ftwp-postcontent h2 { border-bottom: 1px solid #a2a9b1; }
but it only show correct in frontend, I want to show in my editor
How can I do that?
where are you adding the CSS ? eg. the Customizer > Additional CSS or the Child Theme.
I add to : Customizer > Additional CSS
Add this PHP Snippet to your site, and it will tell WP to load those styles in the editor:
add_filter( 'block_editor_settings_all', function( $editor_settings ) { $css = wp_get_custom_css_post()->post_content; $editor_settings['styles'][] = array( 'css' => $css ); return $editor_settings; } );
Adding PHP:
https://docs.generatepress.com/article/adding-php/ -
I added filter, and it don’t show in editor.
After that, I add more CSS (.editor-styles-wrapper_:
#ftwp-postcontent h4, .editor-styles-wrapper h4 { font-style: italic; }
And it still not show in editor
What block in the editor has this ID
#ftwp-postcontent
#ftwp-postcontent this is id at frontend content (content body)
Hi Vovi,
Can you try using a class selector in your CSS instead of an ID to test?
I changed my css to:
#ftwp-postcontent h4, .editor-styles-wrapper h4, .entry-content h4 { font-style: italic; }
It still not show in my editor
Can you try editing it to this to test?:
#ftwp-postcontent h4, .editor-styles-wrapper h4, .entry-content h4 { font-style: italic !important; }
I tried, but it don’t work too
Do you have a caching/optimization plugin? If so, can you disable that first?
Also, may we know how you added the PHP snippet? Did you use a plugin called Code snippets for instance?
I cleared cache, but it still not work
I using Code snippets to add your filter.
Is the code working on the frontend?
Can you share the link to the site in question?
It is working on the frontend.
https://udumbara.org/pipa-a-wonderful-sound-from-the-heaven/
Can you provide admin login credentials through the Private Information field?
