I sent
Try adding this selector:
.editor-styles-wrapper .wp-block-post-content h4
It don’t work too
You seem to haven’t added it yet.
The code should already be something like this:
Replace this:
.editor-styles-wrapper #ftwp-postcontent h4, .editor-styles-wrapper .editor-styles-wrapper h4, .editor-styles-wrapper .entry-content h4 { font-style: italic !important; }
With this:
#ftwp-postcontent h4, .editor-styles-wrapper .wp-block-post-content h4 { font-style: italic !important; }
I replaced in my main site, but it don’t work
Can you replace it in the Staging site as well? We’ll check what’s occurring.
I replaced in my stagging site, and it don’t work too
It didn’t update. This is what I see added: https://share.getcloudapp.com/rRuzPq48
Can you try disabling all non-GP plugins first to ensure the CSS isn’t being altered by some plugin.
I disabled all non-generate plugins.
Could you test, edit direct in my stagging site?
Frontend classes like:
#ftwp-postcontent
andentry-content
are not present in the editor so they won’t work.
And the code i provided here:https://generate.support/topic/my-custom-css-dont-show-in-editor-in-backend/#post-15847
uses the
block_editor_settings_all
filter.
And that filter automatically adds the editor wrapper class.
So you do not need to include it in your CSS.You can simply do this for example:
NOTE: the staging URL you provided takes me to a wp.com sign up page
I know the code above work. But I only want to change h4 style of my body content.
The code above will change all h4 everywhere.Do you have any other method?
You can use this method to add the CSS only to the editor:
add_filter( 'block_editor_settings_all', function( $editor_settings ) { $css = 'h4 { font-style: italic !important; }'; $editor_settings['styles'][] = array( 'css' => $css ); return $editor_settings; } );
And then keep your current front end CSS as it is.
It worked, thanks
Glad to hear that
