My Patterns changed to misleading SYNC symbol
  • Hi Support
    I have a similar issue to other ticket at https://generate.support/topic/wp-patterns-with-generateblocks-blocks-show-as-1-block-since-updating-to-v-7-0/#post-198842.
    Here is my description of the issue …
    I previously created some of my own patterns, using the WordPress Design/Paterns feature
    Some of my Patterns are SYNC’D & some are UNSYNC’D
    Before upgrading to WordPress 7.0, my SYNC’D patterns had a block symbol in the form of a double-diamond pattern icon & my UNSYNC’D patterns did NOT (had the original ordinary block icon based on the type of block)
    When added to a page, the SYNC’D patterns/blocks retained its (SYNC’D pattern) double-diamond pattern icon & UNSYNC’D patterns had the original ordinary block icon based on the type of block
    However …
    Before upgrading to WordPress 7.0, my UNSYNC’D patterns now have (SYNC’D pattern) double-diamond pattern icon when added/viewed in the page editor.
    – this is misleading/confusing, making you think they are SYNC’D
    – you have to detach the block to be able to edit it (unsynced), which should not be necessary
    (on the plus side) …
    – UNSYNC’D patterns still show as UNSYNC’D in Appearance, Design, Patterns, My Patterns (until you add the pattern to a page, as explained above)
    – UNSYNC’D patterns still show as UNSYNC’D in Edit Page, Block Chooser left-hand panel (until you add the pattern to a page, as explained above)
    – UNSYNC’D patterns already added to pages in the past still show as UNSYNC’D
    (Please see screenshots gallery at https://postimg.cc/gallery/s2TghJ6)
    Can anything be done in GeneratePress to quickly fix this?
    Simon
  • Maybe ignore this Ticket. Clearly it is surely a WordPress issue. I have oped a ticket with WordPress support at https://wordpress.org/support/topic/my-patterns-changed-to-misleading-sync-symbol/#new-topic-0
    That’s correct. Unfortunately, this is how it currently works in WordPress 7.0, and there’s nothing we can do about it from our end at the moment.
    Hopefully, the WordPress team can improve this behavior in a future update.
