My site doesn’t support dynamic image?
    I’ve get this message on some of my posts:
    Your site doesn’t include support for the “generatepress/dynamic-image” block. You can leave this block intact or remove it entirely.
    In the meantime the Author avatar appears on front end. You can check here:
    https://legit.casino/news/betmarket-declared-bankruptcy/
    That’s odd, can you try disabling all plugins except GB and GP Premium to eliminate plugin conflicts first?
    I’ve fixed the problem by using Element block. In Elements there is no such a problem.
  • The problem appeared again on completely new post. I can’t use the Dynamic image block. Should I try with disabling all the plugins?
    use the GenerateBlocks Image Block in a post or page.
    It has its own dynamic data settings.
    The GeneratePress Dynamic-image block can only be used inside a GP Block Element. ITs a legacy block, and where possible use the GenerateBlocks Image Block instead
  • Thanks David. It works that way.
    Regards
  • Glad to hear that!
