Navigation Block: Deep nesting?
    My initial question is if the new navigation block can handle deep nesting, or if there are caveats to this behavior? I am unable to expand a link from a basic Parent > Child > Grandchildren structure.
    Thanks.
    For nested submenus, the best approach might be to change the dropdown direction to the side instead of the default downward direction. This requires a small tweak if you’re using the Navigation block.
    Could you share a link to your site so I can take a look at the menu you’ve built?
