navigation block hover color not working
  • On my staging server, the GenerateBlocks navigation block hover color is set to red but it is not working on the frontend. The backend displays the correct hover color but the frontend does not. The hover color is displaying incorrectly as black even though it is set to red in the Menu block and in the Menu Item block.
    Since I could not get this to work, I had to use the Gutenberg navigation block on the live production site. This displays the hover color at white (though it is also set to red) but at least it isn’t black. However, I would like to fix this issue, so I can use GenerateBlocks navigation.
    The staging site is behind http authentication, could you please provide access details in the private section?
  • I added it in the private section below.
    How did you set the hover color in the navigation block, can you send us a screenshot?
  • I added the login below. I thought that might be easier since I added the hover color in various areas during troubleshooting.
    Under Customize > Colors > Content > Link, remove the Link Hover color that is currently set to black.
    That should fix the issue.
  • Thank you! This fixed the problem.
  • Glad to hear that!
