How can I make such Navigation Boxes like on this website? Three side by side and with this effect when you hover over an image with the mouse.
George
Hi there.
It’s possible with GenerateBlocks and GenerateBlocks Pro.
This is essentially a 3X3 container grid. (Grid Template Columns:
repeat(3, minmax(0, 1fr))that goes to1fron mobile). For the image hover effect, you do the following:1. Insert a container and set position to relative. Set its tag to be a link. (
atag) and set you link destination in there. Set the background image to #FFF. Set OVERFLOW-X and OVERFLOW-Y values tohidden.
2. Insert image inside the container, set Display toBlock. Create a TRANSITION effect and set duration to 0.3s.
3. Below, insert a shape block with the magnifying glass, set the color to a dark one and OPACITY to0. Set position toAbsolute, with Inset:50%for Top and Left. Add a Transform effect with Translate effect type and set Translate X and Translate Y to –50%. This will essential center the magnifying glass horizontally and vertically in relation with the image.
4. Select the initial container and create a new selector, name it &:hover img. Set the opacity to 10% or similar.
Also, create a Transform effect, with the Scale type and a SCALE value of 1.1.
5. Select the initial container, create a new selector and name it
.gb-shape. Create a TRANSITION effect and set duration to 0.3s.
6. Again, select the initial container, create a new selector and name it
&:hover .gb-shape.
Set OPACITY to 100%.
That should create the effect you want.
Thank you for your instructions. Unfortunately, it sounds very complicated to me and I got stuck on the first point.
Where do I set the size of the grid boxes, where do I Put this “repeat(3, minmax(0, 1fr))” and how do I get the text under the images?
Edit:
I have found where to set the “repeat(3, minmax(0, 1fr))”, it was on the other tab.Should the text under the image also be placed in a container?
George
There are going to be containers for all grid items. The instructions I provided were only for the image hover area. That is going inside the parent containers of each grid. So each grid item will have:
Parent container (probably with a grey background to emulate your example)
— Container for image (instructions I provided)
— Title text
— Description text
— Button (Details)Hope that’s clearer.
Do you mean:
Parent container
— Container for Title text
— Container for Description text
— Container for Button?
George
Title, description and button can go below the Container for image. They don’t need to be inside a container.
okay, thanks, I will try this.
George
List view will look something like this.
