cookgirl26
Hello, I purchased the theme subscription a month ago; but haven’t been able to go live with it yet because I’ve been having trouble customizing the navigation search modal on my staging site. I’ve tried creating one in elements and also without using elements, but it just won’t take on my custom color and other customizations. Also, a big issue I’ve been facing is getting the exit x to show through the modal. No matter what codes I try, that exit x won’t appear.
The link you provided is the WP login page, I’m not sure if you are aware of that.
I checked your site’s homepage, the navigation search modal you are referring to is not from GP.
To enable GP’s navigation search modal, simply go to customizer > Primary Navigation, and check the Enable navigation search modal box.
For more info: https://docs.generatepress.com/article/navigation-search-modal/ -
cookgirl26
I’m on a staging site, so I didn’t really know what url to use. But that modal you saw wasn’t the modal I’m talking about here. That was a test modal, and it’s gone now. The reason why I tried that modal was to see if there was an x or close showing to exit out of it.
The reason why, is because on my staging site with the Generate Press theme, when I click on the search icon; the modal comes up with the search box. But there’s no visible x or close sign anywhere for people to see and be able to exit the search modal.I’m using the default search modal color. Also, I’ve been trying to customize the search box with my custom color and other styles but it won’t customize fully. A couple of things are customized while other things aren’t.
I just can’t figure out why I can’t see a visible way out of that modal screen, and the lack of customizations to the search box area, after trying multiple codes. What url do I provide if I’m on a staging site, since i have a live site also? Thanks!
Could you provide the site URL again so we can take another look? Sharing the specific page URL where the issue occurs would be especially helpful.
cookgirl26
What url do I provide if the issue is on a staging site (wp staging) with the Generate Press theme? Usually it asks you for a username and password..
You can create a temporary admin account and share the credentials with us. When doing so, please use the Private Information section so that only the support team can view it.
cookgirl26
Hello, here are the temporary login credentials for my staging site. Again, this is in reference to the search navigation modal missing its exit/close sign. Also I’ve tried to customize the search box with my custom color and other styling, but only a couple of those customizations have worked each time I tried.
No extra plug-ins or GenerateBlocks were used to create the modal. It’s the default one, with the default modal overlay color. The site is on a Litespeed server but the plugin has been deactivated on this staging site. Thanks!
cookgirl26
In addition, in reference to the search modal, can that little blue x inside the search box be removed? Thanks!
It does not need a close icon; you can click anywhere outside the search box to close the modal.
Here’s a screen record for your reference: https://app.screencast.com/FgQUSIXocaeqR -
cookgirl26
How are any visitors supposed to know that? Just click anywhere… I was told that there’s supposed to be an exit x or visible sign that lets people know how they can exit that screen..
I understand the ‘click-to-dismiss’ feature exists, but for my mobile audience, a clear visual ‘X’ or ‘Close’ button is a non-negotiable UX requirement. I need the exit icon to be visible to ensure my visitors don’t feel trapped. Can you please help me ensure the standard SVG Close icon is rendering correctly? Thanks.
I have never seen complains for not finding the close icon for the search modal, so I think most people can figure it out.
And I really don’t think you need a close button, as you can see the one you are testing right now, does not have a close button as well, it’s just not standard for search forms. You can try WP’s search block as well, it doe snot have a close button either.
cookgirl26
I appreciate your perspective, but for a food blog where 85% of my traffic is mobile, ‘click-to-dismiss’ is not a reliable UX for my audience. I want to ensure my site is fully accessible. Since the default SVG close icon isn’t appearing, please assist me in creating a Search Modal Block Element. This will allow me to visually include a ‘Close’ or ‘X’ button so my visitors never feel trapped.
Question: Was the modal created with an exit sign or anything or not?
No, there isn’t a default exit sign or anything like that. As I said, you can click anywhere to exit; you do NOT need to click on a close icon to exit.
To add a button to act as a close button, you will need to write custom JS. Is it the path you want to go forward with?
If so, you can go to appearance > elements, create a new block element – search modal, and paste the blocks in. Screenshot for your reference: https://app.screencast.com/WYcjove3ixguQ
<!-- wp:html --> <form role="search" method="get" class="search-modal-form" action="https://clean.local/"> <label for="search-modal-input" class="screen-reader-text">Search for:</label> <div class="search-modal-fields"> <input id="search-modal-input" type="search" class="search-field" placeholder="Search …" value="" name="s"> <button aria-label="Search"><span class="gp-icon icon-search"><svg viewBox="0 0 512 512" aria-hidden="true" xmlns="http://www.w3.org/2000/svg" width="1em" height="1em"><path fill-rule="evenodd" clip-rule="evenodd" d="M208 48c-88.366 0-160 71.634-160 160s71.634 160 160 160 160-71.634 160-160S296.366 48 208 48zM0 208C0 93.125 93.125 0 208 0s208 93.125 208 208c0 48.741-16.765 93.566-44.843 129.024l133.826 134.018c9.366 9.379 9.355 24.575-.025 33.941-9.379 9.366-24.575 9.355-33.941-.025L337.238 370.987C301.747 399.167 256.839 416 208 416 93.125 416 0 322.875 0 208z"></path></svg></span></button> </div> </form> <!-- /wp:html --> <!-- wp:generateblocks/text {"uniqueId":"17b505fc","tagName":"button","styles":{"display":"inline-flex","borderRadius":"10px","alignItems":"center","backgroundColor":"#ff5722","color":"#ffffff","paddingTop":"1rem","paddingRight":"2rem","paddingBottom":"1rem","paddingLeft":"2rem","textDecoration":"none","\u0026:is(:hover, :focus)":{"backgroundColor":"#e64a19","color":"#ffffff"},"columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"position":"absolute","top":"-10vh","right":"5px"},"css":".gb-text-17b505fc{align-items:center;background-color:#ff5722;border-radius:10px;color:#ffffff;column-gap:0.5em;display:inline-flex;position:absolute;right:5px;text-decoration:none;top:-10vh;padding:1rem 2rem}.gb-text-17b505fc:is(:hover,:focus){background-color:#e64a19;color:#ffffff}.gb-text-17b505fc .gb-shape svg{width:1em;height:1em;fill:currentColor}","htmlAttributes":{"aria-label":"close search form"},"iconOnly":true,"className":"close-search"} --> <button class="gb-text-17b505fc close-search" aria-label="close search form"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" fill="none" viewBox="0 0 13 13" height="13" width="13"><rect fill="currentColor" transform="rotate(-45 0 11.4497)" rx="1" height="2" width="16" y="11.4497"></rect><rect fill="currentColor" transform="matrix(-0.707107 -0.707107 -0.707107 0.707107 13 11.4497)" rx="1" height="2" width="16"></rect></svg></span></button> <!-- /wp:generateblocks/text -->Once it’s done, add this JS to a hook element, set the location to the entire site, and hook name to
wp_footer.<script> document.addEventListener('DOMContentLoaded', function () { const closeButton = document.querySelector('.close-search'); const overlay = document.querySelector('#gp-search .gp-modal__overlay'); if (!closeButton || !overlay) { console.warn('Close button or overlay not found'); return; } closeButton.addEventListener('click', function (e) { e.preventDefault(); e.stopImmediatePropagation(); // Simulate a real click on the overlay → this is what GP uses to close the modal const clickEvent = new MouseEvent('click', { bubbles: true, cancelable: true, view: window }); overlay.dispatchEvent(clickEvent); }); }); </script> -
cookgirl26
Thank you so much! But, can I remove the little blue x inside the search box? And possibly change the shape and color of the box? In addition, can I choose where on the screen to add this exit button?
No, that’s to clear the search term.
Yes, custom CSS is required. What changes do you want to make?
Yes, but limited, so not everywhere. Where do you want to position it?
cookgirl26
Can I change the color to my custom color of #8c5e32 (the blue x)?
I would like the top right location for the exit button.
As for the shape of the search box, I would like it to have my custom color border with these dimensions: border-radius: 6px !important;. Thanks.
