Need argent help with GenerateBlock 2.0
  • I am having issue while embedding video from vimeo. It is breaking container. I have added screenshot in private, also added site url.
    The embedded video has its own sizing attributes, which GB can not control.
    If you want the video not to overflow the container, set the container’s overflow-x and overflow-y to hidden.
    You should also remove the min-height, height, max-height set to the container, the video won’t adapt to the size you determined for the container.
