lohith
Hi fernandoazarcon2,
I am able to make the changes as per your feedback. The featured post is appearing fine. Thank you for that. Can you please guide me how can we align the rest posts like https://blog.zoom.us/
Here is my blog link: https://tenxerlabs.com/blog/
nixninja
Hello @fernandoazarcon2
This is exactly what I am looking for as well for site https://itnixpro.com.
I however need to maintain top menu, site logo, and main header, search box just after main header, and the footer in place.
Can you please urgently help me. I have tried to do this but still havent figured out so far to match this.
Looking forward to hearing from you as soon as possible.
fernandoazarcon2
Hi Lohith,
Can you first set the column number to 3 in Appearance > Customize > Layout > Blog? Reference: https://docs.generatepress.com/article/blog-overview/
Hi @nixninja,
Can you open a new topic regarding the issue? We’ll try to assist you in your new topic thread.
lohith
Hi
I set column number to 3 but design got broke. Here it is: https://tenxerlabs.com/blog/
fernandoazarcon2
Try adding this through Appearance > Customize > Additional CSS:
.generate-columns-container .featured-column { float: none; width: 100%; }
lohith
wow this worked like charm. Thank you. Can you please help how can I set more width to the images. I have set images 500* 230 but the space between images horizontally are not narrowing down.
fernandoazarcon2
Are you referring to reducing the gap? If so, you can first remove the left and right padding in the Container Block in your Content Template.
Then, you can add padding to the content through Appearance > Customize > Layout > Container.
lohith
Hi I removed the space padding in content template:
https://share.getcloudapp.com/xQuEK1oEand set separate space 20 and content space 40:
https://share.getcloudapp.com/v1uWow9A
I am able to reduce the space between containers but not able to give space to right and left side of the layout. like how I have done for featured post.
fernandoazarcon2
Can you set this Element – Blog Home Page you have first to draft?
lohith
As you said yesterday to create from scratch, I put those two old elements in draft mode. And created new one which I renamed Blog Home Page Brand New and Blog Home Page First Post Brand New.
By doing this I was able to fix old issues. The element which you are seeing is already set:
