Need Help Removing Sidebars from Custom Post Type Archives
  • I’m building a site with a custom child theme and having trouble
    removing sidebars from our custom post type archive pages.
    Setup:
    – GeneratePress Pro (latest version)
    – Custom child theme
    – Custom post types registered via plugins
    – Custom archive template at:
    https://zippicks.com/vibes/
    Issue:
    The sidebar still appears on our custom archive pages (e.g., /vibes/) despite trying
    multiple approaches:
    What I’ve tried:
    1. Adding filters in the template file:
    remove_action(‘generate_before_main_content’, ‘generate_construct_sidebars’);
    add_filter(‘generate_sidebar_layout’, function() { return ‘no-sidebar’; });
    2. Adding hooks in child theme functions.php at various priorities
    3. Using CSS to hide sidebar elements with !important
    4. Removing all sidebar-related actions
    None of these approaches have worked. The sidebar continues to display.
    Questions:
    1. What’s the correct way to remove sidebars from custom post type archives in
    GeneratePress?
    2. Are there GP Premium modules that might be overriding these settings?
    3. Is there a specific hook timing/priority I should use?
    Any guidance would be greatly appreciated. Thank you!
    Using CSS would be the easier option here, but when I checked the archive link you provided, it appears to be showing a blank page. Did you remove the archive layout? Let me know so I can take a closer look.
  • Hi Alvind,
    Thank you for the follow up. It should be visible now – https://zippicks.com/vibes/. Would you recommend the CSS in the child theme or the plugin?
  • I am seeing a blank page as well.
