Need more Elements because limit of 500 reached
    I recently reached the limit of maximum 500 elements created and now i am stuck.
    I need at least another 200-300 additional to create.
    The problem is that i am attaching the Elements to Custom Taxonomies and this is the only way to do it.
    I can’t find any workaround and I can’t go on with my work.
    For example – https://legit.casino/online-casinos/licenses/malta/
    Any help will be greatly appreciated.
    Thank you!
    As we’ve discussed before, there isn’t a filter to increase the limit, unfortunately!
    I recommend tidying up your elements and trying a dynamic way to create them.
  • Any suggestions how i can skip the element to these pages and generate it other way?
  • I assume you are adding static content to each page via elements. If so, you can create custom fields to store the static content and use GB’s text block/image block to pull the content dynamically in the elements.
    Thank you for your response.
    But can you please clarify more in details because i don’t get your idea.
    Thanks in advance.
    Regards
  • Do you know how to create custom fields? you can use WP’s built-in ones, or use a plugin like ACF.
    I assume there will be lots of articles on how to do that, so please do your own research on this part.
    Once the custom fields are created and filled for each posts/pages, you can use GB’s text block/image block to pull the content from the custom fields dynamically via the dynamic tag feature.
    For example, let’s say you want to add different subtitle to each post, so you created 50 elements with static content for 50 posts. But with the method I suggested above, you only need 1 element with a dynamic tag, as the dynamic tag is pulling content from the custom field of each post. Hope that’s clear!
