Stephan Koenigk
Hi everyone,
I sat down and customized the error messages for incorrect input by disabling browser-side validation and writing my own warnings using JavaScript.
So far, it’s working great. Now I’d like to add a red border around the corresponding input field when incorrect data is entered, as an additional visual cue.
Can I do this using GenerateBlocks’ features? Maybe even with an additional warning symbol (icon) as another option for people with color blindness, for example?
The URL where I have implemented the form: https://installation.design-netzwerk.eu/contactform/
Thank you in advance
Stephan -
George
Hi Stephan,
Since your script already sets
aria-invalid="true"/"false"on each field, you don’t need to change the JS at all — that attribute is the perfect CSS hook. This is plain CSS rather than a built-in GB feature, so you can add it to your existing custom CSS:.gb-form-field__input[aria-invalid="true"] { border: 2px solid #b90000; background-image: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 512 512' fill='%23b90000'%3E%3Cpath d='M256 32C132.3 32 32 132.3 32 256s100.3 224 224 224 224-100.3 224-224S379.7 32 256 32zm0 384a32 32 0 110-64 32 32 0 010 64zm24-152a24 24 0 01-48 0V152a24 24 0 0148 0z'/%3E%3C/svg%3E"); background-repeat: no-repeat; background-position: right 12px center; background-size: 20px; padding-right: 44px; } /* For the textarea, pin the icon to the top instead of vertical center */ textarea.gb-form-field__input[aria-invalid="true"] { background-position: right 12px top 12px; }The border gives the visual cue, and the inline SVG adds a warning icon as a second, non-color signal — which is exactly the right approach for color blindness. No extra ARIA is needed for the icon, since your
aria-invalidplus thearia-describedbyerror text already convey the error to screen readers.Since your
inputhandler resetsaria-invalidto"false"on the first keystroke, the border and icon clear automatically the moment the user starts correcting the field — which works out nicely. -
Stephan Koenigk
Hey George,
this works fine, thank you for your fast and effective help!
George
Glad it’s working, no problem!
