new navigation blocks issue when placed at bottom
    I set a language menu for the new navigation blocks on the footer, but when I hover over the menu, the submenu alway appears below the menu block, which exceed the bottom of the footer, is there anyway can make the submenu appear above the menu block like this https://dropover.cloud/a05b48
    Alex
    Edit the Navigation block and select the Sub Menu block inside it. Then, under Position > Inset set the Bottom value to 40px.
  • great, it is working now, thanks!
  • You’re welcome!
