Inside a Post Template (Content Template), I noticed Next and Previous Post URL’s are not outputting anything on the front end. Is this a glitch?
Hi Ian,
That’s a known bug in GP Premium, and hopefully we’ll be able to address it in the next release.
For now, one workaround is to install and activate GB Pro, which resolves the issue.
Alternatively you can instead use this snippet-based workaround:
https://generate.support/topic/query-pagination-next-button-issue-with-gp-elements-module/#post-192687 -
Interesting. I tried the snippet, Previous and Next links do not display.
Activated GB Pro and GP Premium, still no links displayed.
I wonder if this is still related to the same bug? Going back to the default post template for now until there is a fix rolled out.
Thanks.
That could be a different issue in that case. If you’d like us to take a closer look, just let us know.
