Anonymous
I’m working on a website that had an ACF data type that includes GPS coordinates; and on the single page for that data type, I am displaying that map using the ACF Map field type (with dynamic data – {{post_meta key:map}}). I don’t want this map to show up if I don’t enter in the GPS coordinates, and it’s set to require value to render, but the map seems to have a default location. Is there a way to fix this with Generate Press, or should I contact the ACF support? I’ll include a link to a page below, where the sign doesn’t have location data attached to it (but the map is still showing up).
Elisabeth -
Hi Elisabeth,
If the field has a default value, then it’s not something that GB can fix.
You will need to check with ACF’s support on this, ask them how to remove the defualt value.
Anonymous
Ok thanks, I will do that. In case they can’t help, would there be a way to make the map not show up if a certain set of values (i.e. in the ocean, 0,0 GPS coordinates) are inputted? Maybe through a PHP function?
Thanks,
Elisabeth -
George
ACF only seems to have a Google Map field, is that what you are using?
Anonymous
No, I’m using the openstreet map field.
George
I am not able to display the map in my local install. Please provide details with your ACF settings. Is it this plugin you are using?
Anonymous
I’m using ACF’s field type called OpenStreetMap and yes, that’s the plugin I’m using.
https://wordpress.org/plugins/acf-openstreetmap-field/
If you want to check it out on the back end, I included login info below, as well as a screenshot of the ACF field group. -
George
Hi Elisabeth,
After some investigation, the issue is that the ACF OpenStreetMap Field plugin retains the map center coordinates in the database even when the field is cleared — so GB’s “require value to render” sees a non-empty value and renders the map regardless.
The fix involves two parts: a custom GB Pro display condition that checks whether the map field has a valid location, and a small snippet that clears the meta when the field is saved without a marker.
Add the following to your child theme’s
functions.phpor a code snippets plugin:class GB_OSM_Map_Condition extends GenerateBlocks_Pro_Condition_Abstract { public function evaluate( $rule, $operator, $value, $context = [] ) { switch ( $rule ) { case 'osm_has_location': $post_id = $context['post_id'] ?? get_the_ID(); wp_cache_delete( $post_id, 'post_meta' ); $map = get_post_meta( $post_id, 'map', true ); $has_location = ! empty( $map ) && is_array( $map ) && ! empty( $map['lat'] ); return 'is' === $operator ? $has_location : ! $has_location; default: return false; } } public function get_rules() { return [ 'osm_has_location' => __( 'OSM Map Has Location', 'generateblocks' ), ]; } public function get_rule_metadata( $rule ) { return [ 'needs_value' => true, 'value_type' => 'text', 'supports_multi' => false, ]; } public function sanitize_value( $value, $rule ) { return sanitize_text_field( $value ); } } add_action( 'generateblocks_register_conditions', function() { GenerateBlocks_Pro_Conditions_Registry::register( 'osm_map', [ 'label' => __( 'OSM Map', 'generateblocks' ), 'operators' => [ 'is', 'is_not' ], 'priority' => 100, ], 'GB_OSM_Map_Condition' ); } ); add_action( 'acf/save_post', function( $post_id ) { $field_key = 'YOUR_FIELD_KEY'; $raw = $_POST['acf'][ $field_key ] ?? ''; if ( empty( $raw ) ) { update_post_meta( $post_id, 'map', '' ); return; } $data = json_decode( stripslashes( $raw ), true ); if ( empty( $data['markers'] ) ) { update_post_meta( $post_id, 'map', '' ); } }, 20 );Once the code is in place, edit the map block in your GP template and add a Display Condition: OSM Map → OSM Map Has Location → is, with map as the value. The block will then only render when a valid location has been saved.
I have tried this solution locally and it worked. If it doesn’t work for you, you would need to get in touch with the plugin developer and point out this bug.
Anonymous
That worked – thank you so much George!
George
No problem!
Anonymous
Hi George,
I just noticed that the map field no longer seems to be saving map locations when I enter gps coordinates for new signs. The ones that existed before I added the code are still showing up, but none after that. Is there something that needs to change in order to add a location to a sign? -
George
How do you enter the coordinates? For example, when I enter coordinates for London:
51.5074, -0.1278, then click the magnify button to search for them, the location is found. When I save the post, I can see the map with the new coordinates in the front end. -
Anonymous
I enter the coordinates into the map field (which is a field in the sign details field group), for example, “34°3’49” N 4°58’21” W” and they show up. When I update or save the post, the coordinates are gone, and nothing shows up on the back end. I’ll include the link below for the post with the coordinates 34°3’49” N 4°58’21” W.
Elisabeth -
Do you mean the coordinates are gone from the field?
Anonymous
Yes, the coordinates are gone and it’s reset to 0, 0.
It sounds like an issue with the field plugin itself.
Can you remove George’s code and test it again?
