No Form Block
  • I installed the latest versions of GenerateBlocks and GenerateBlocksPro and wanted to create a contact form as a test. It worked perfectly. However, when I try to insert the form into a post or page, I’m not offered a corresponding block. Only the usual blocks—such as Container, Image, Accordion, Button, etc.—are displayed, but there’s no block for forms.
    What am I doing wrong?
    Just wanted to confirm. The new form block is not part of the latest GB Pro version, only part of the upcoming GB Pro 2.6.0 which is current in RC2 status. Have you installed this version along with the corresponding GB 2.3.0-rc.1 one?
  • Yes, both plugins are installed in exactly this version.
    Are you not seeing the form block?
    Form block
    Do you happen to have v1 blocks activated by any chance from GenerateBlocks -> Settings?
    v1 blocks
  • Perfect—that was exactly the problem, or my mistake. Great job. Thanks so much.
  • Ok, no problem!
