I wanted to look at the pattern library on the url: https://generatepress.com/pattern-library/
But there are no pattern. It only shows the text “No patterns found”.
Is the problem known?
yes we are aware of the issue, it will be back online soon.
Today I’ve had no patterns displayed all day again. What’s going on?
It should be resolved now. We haven’t made any changes on the server, so it was likely an intermittent issue.
Once again, no patterns are displayed. I have to honestly say that the problem is very annoying and irritating.
It works for me. Can you check?
Now, it works for me too. But almost every time I try to look there, it doesn’t work.
Once again, no patterns are displayed. It happens every day!
I just checked and it’s working for me.
Can you check again?
Yes, it’s working again now. But every time I wanted to look at patterns in the last few days it didn’t work. Only when I post it here and then someone replies telling me to look again, does it work again. Until the next day, when it doesn’t work again. This can’t be a permanent situation.
If it’s down on the site, you can always check it in your block editor.
