Anonymous
Hi team,
I am using your ‘Wilder’ Starter Site and have established that the menu is being presented in a Header Element using the Block -Site Header. This is fine, but how can I add a Sticky Navigation? Nothing happens when I turn on Sticky Navigation?
The sticky behavior for the Site Header block is configured directly in the block settings.
Edit the Header element, select the Site Header block, and set Sticky Header to Always Sticky:
https://learn.generatepress.com/blocks/block/site-header/#sticky-headerCurrently the header remains transparent in its sticky state. To apply a background color, switch to the Sticky selector from the Manage Selectors, then set the desired background color: https://cln.sh/B5cfwjyzYvTYGJS6PgKd
Anonymous
That’s it, thanks Alvind.
You’re welcome!
