Hridoy
Not able to remove Menu text
I already removed the Menu text from the primary navigation. But still, when I visit my website from mobile, the Menu text is still showing.
Image: https://postimg.cc/64vHMbf5
My website: https://saasdirectories.io/
How do I remove it?
Can you disable your cache plugin to test?
Hridoy
I tried. Didn’t work.
Can you provide an admin login to your site so I can check your settings?
Hridoy
Instead, give me your email. I’ll add you as an admin.
George
You can use [email protected]
Hridoy
Hi, I just added you. Check your email.
George
Hello, it seems that the email has not been sent. You could potentially also install the Temporary Login Without Password plugin and send us a login link without using a password. Please, use the private area of your reply to send those details.
Hridoy
Okay, I added.
George
Seems like it’s working when logged in so the issue is probably the cache. Can you try clearing it?
Hridoy
However, it is now working after turning off the minify option from the caching plugin.
By the way, thanks…
George
Ok, I see.
Please, check now. All I did was entered some text for the mobile menu, saved the Customizer, then removed the text and resaved the Customizer. Must have been some hiccup with CSS regeneration.
Hridoy
It is now working after turning off the minify option from the caching plugin.
By the way, thanks…
George
Ok, glad it’s working!
