Not showing “footer” tag in site_footer
  • Site URL: https://wp-blog.co.kr/main/
    Hi, I have created an element and I have set element type is equal “Site Footer”. But it generates “div” tag instead of “footer” tag.
    <div class=”site-footer”>
    </div>
    Can anyone tell me how can I generate “footer” tag?
    Thanks.
    Edit the Footer Element, select the outer container, and you should be able to change its tag to <footer> under Advanced > Tag Name settings in the Block settings sidebar.
  • If I follow you, it adds the footer tag inside “.site-footer” class. But I want <footer class="site-footer">
    <footer class=”gb-container gb-container-73cd57e1″>
    </footer>
    </div>
    I need semantic layout.
    e.g.
    <header class=”site-header”></header>
    <main></main>
    <footer class=”site-footer”></footer>
  • I see. It looks like there’s no way to achieve that at the moment, as the div with the site-footer class is needed to serve multiple purposes for features utilized by the theme.
