karstenkagels
Hello friends, I am using currently the Off Canvas Menu which contains nearly 800 blog posts. Please take a look here:
https://www.kagels-trading.de/
It becomes very difficult to add new posts or even more difficult to reorder this many blog posts in the off canvas menu. I have a very fast Macbook, but this doesn’t help much.
I like the off canvas very much in order to present my content to my website visitors. But somehow it seems to me that there could exist a better possibility or plugin in order to handle my website content.
Do you have a recommendation for me how to improve the off canvas menu?
This would be very helpful.
Thank you very much,
Karsten
Hi Karsten,
I recommend using GB query block to pull the posts from certain categories as your sub menus.
In order to do so, I’ll take category Kursprognosen as an example, follow the steps:
1. Go to appearance > menu, create a new menu, keep your current slide-out menu for now, and assign the new menu to slideout nev.
2. In the new menu, only create the top level of menus, like
Kursprognosen.3. add classes
menu-item-has-childrenandgp_mega_menuto the top level menu item:
https://app.screencast.com/nsR5MvS4KePLl4. Create a block element – hook, set hook name to custom hook >
gp_mega_menu_categoryname, so in your case, the hook name would begp_mega_menu_kursprognosen,5. Add a query block in the block element, you only need 1 text block to pull the title and post link, add Taxonomy parameter, select the categories, and choose
kursprognosen.6. Add this PHP code to create the custom hook:
add_filter( 'walker_nav_menu_start_el', 'db_sub_menu_item_hook', 10, 4 ); function db_sub_menu_item_hook( $item_output, $item, $depth, $args ) { // Specify menu item class to target $class_string = 'gp_mega_item'; $menu_item_classes = $item->classes; if ( empty( $menu_item_classes ) || !in_array( $class_string , $menu_item_classes ) ) { return $item_output; } $menu_item_slug = $item->post_name; // create custom hook from $class_string and $menu_item_slug // example result gp_mega_menu_{menu-item-name} $custom_hook_name = $class_string . '_' . $menu_item_slug; // Add our common and specific hooks ob_start(); ?> <ul class="sub-menu custom-sub-menu"> <?php do_action('gp_before_mega_item'); ?> <?php do_action($custom_hook_name); ?> <?php do_action('gp_after_mega_item'); ?> </ul> <?php $custom_sub_menu_html = ob_get_clean(); // return the output after the menu items anchor $item_output .= $custom_sub_menu_html; return $item_output; }Adding PHP: https://docs.generatepress.com/article/adding-php/
7. Repeat steps 2,3,4,5 for other categories.
Let me know if this helps!
karstenkagels
Thank you very much for your helpful support, dear Ying. I will try your solution.
Hope it works out nicely!
