websquared
Annoyingly siteis behind a secure wall – but I will try to replicate it on a site that I can share
However using the off canvas menu as the primary menu – so burger menu showing in header – great
logo is to left and menu is to right – great
I then want another “account” menu – so I can add it either as a menu item or a HTML item within the header widget but it always sits to the right of the burger icon – is it possible to have it above the burger item
Almost like 2 header blocks on top of each other both to the right of the logo ?
Thank you
Sarah -
Try using the block element – hook to insert the account button, set the hook to
menu_bar_items
.Once it’s done, Let me know and link me to the site.
websquared
Thanks Ying – that just added it to the left of the off canvas menu – so I actually used the CSS from this post and moved the header widget instead
https://generatepress.com/forums/topic/position-header-widget-directly-above-navigation/
I can imagine I could have easily done it both ways but this made more sense – oddly 🙂
Glad you’ve figured it out 🙂
websquared
ooh I am entrigued… I cannot show you the site still behind a secure wall as customer does want it live – are you able toexplain how I can split that mend-bar-items then?
Took another look, it still requires CSS 🙂
