johnottomagee
Hello Folks !
On a smartphone please see the menu of:
https://understand-culture.com/Choose the topic Persuasion under
Germany, United States, or Contrasts.How can I remove the white background behind
any choice made?Thanks.
John
Hi John,
Are you referring to this section?
https://cln.sh/38lbCHXn -
johnottomagee
Yes, Alvind.
Try going to Appearance > Customize > Colors, then under Off Canvas Panel, remove the color set for the Sub-Menu Background option.
johnottomagee
How do I remove the color set?
Simply remove the color value and leave the field empty: https://cln.sh/SfdnT904
johnottomagee
Hi Alvind,
Thanks for the video.
Yes, I tried that.
It did not work.I suspect we have
some CSS in play here.Any ideas?
Do you have a cache plugin? If so, can you disable them so we can see the CSS?
johnottomagee
Hi Ying,
I do not have a cache plugin.
Should I give you a list of my plugins? -
Can you try removing all 3 background colors for the slideout submenu?
https://app.screencast.com/uZZpkqlsXN1RT -
johnottomagee
Still white background, Ying.
Just took another look, and it seems the background color has changed to a subtle grey:
https://cln.sh/4sWYNbbLIs this the color you want, or do you want it to be transparent?
