Off Canvas Panel elements alignment
  • As David said, I raise a separate topic:
    What I want to achieve is to align items in slide out menu as seen on the example:
    The logo image is set in an Element hooked in “generate_inside_slideout_navigation”.
    The social icons are made with social icons block from default Gutenberg block.
    try this CSS:
    #generate-slideout-menu .inside-navigation {
        height: 100%;
        flex-direction: column;
        align-items: flex-start;
        padding-bottom: 40px !important;
  • It works. Thank you David!
  • Glad to hear that !
