Order by custom field value in Query Loop block v2
  • I’m curious if, since v2, there’s a new way to order by a custom field value in the query loop block, or if I need to use the custom class to filter the query args using a function (like in v1)
    Thanks.
    Unfortunately, there isn’t a built-in way to do this!
    Just note that the filter for v2 query block is generateblocks_query_wp_query_args instead of generateblocks_query_loop_args.
