Search for: Order in mobil afuente June 15, 2026 at 12:19 am Hello, I use the order propety to display the image first and the text-block the second. But it doesn´t work on mobil version. Thanks Angel George June 15, 2026 at 3:52 am Hi Angel, Keep the Display as Grid for mobile as well (set it to Display Default instead of Block so it will inherit the Grid layout on mobile), then set the GRID TEMPLATE COLUMNS value to 1fr on mobile. No need to mess with the order. Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic.
