Anonymous
I have created a Grid container and used a Background SVG with a Text Overlay to create a badge. This works fine. I have then added a small bit of text to the right of it, in its own container, however, the text is pushing into my badge and breaking it. How do I seperate the badge and the text, so the badge stays intact.
Anonymous
OK, so I have finally managed to align them, but I’ve had to change the 2 inner containers to V1, as the v2 containers simply were not cooperating. The container they are in is still V2 and I have had to make some strange adjustments to get this to work. Is there a simpler way this can be done using V2 or am I best to avoid V2 for this kid of stuff?
It looks like you’ve already resolved the spacing between the badge container and the text container.
To vertically align the text in the center, try the following:
– Select the left column container that contains the SVG image and set its Min Height to 120px.
– Then select the right column container that contains the text, set its Display to Flex, and set Align Items to Center.
– Finally, select the Text block inside that container and set its Bottom Margin to 0.
Anonymous
I think I managed to get it working with V1 blocks, so I guess that will do. Thanks
No problem, glad to hear that!
