Overlay Panel not accessible when W3 Total Cache active
  • Hello!
    I am having this issue: the overlay panels are not accessible when W3 Total Cache is active. I suppose it could be a setting of the cache plugin.
    What could it be that interfere with the overlay and conditions pages?
    This is most likely caused by W3 Total Cache’s JavaScript minification. When JS files are combined or reordered, it can break the overlay panel’s trigger and open/close logic.
    To narrow it down, try disabling these W3TC features one at a time (testing after each):
    1. JS Minification — Should be at Performance → Minify → uncheck “JS minify” (this is the most likely culprit)
    2. CSS Minification — same area, uncheck “CSS minify”
    3. Page Cache — temporarily disable to rule out stale cached markup
    If disabling JS minification fixes it, you can re-enable it but add GenerateBlocks Pro’s scripts to the exclusion list instead of disabling minification entirely. The script handles to exclude would typically start with generateblocks-pro.
    Let us know how that goes!
  • Hello George, and thanks for the support.
    I don’t use minification, but I did use page cache. Disabling it, though, didn’t solve the issue.
  • the overlay panels are not accessible when W3 Total Cache is active
    I assume this happens in the front end? Can we see a URL?
  • No, it’s happening in the backend. The overlay are visible in frontend, but I cannot edit them in any ways on the backend.
  • That’s weird, cache plugin should not affect the admin area, can you check with the cache plugin’s support?
  • That’s what happened,
    I switch to WP Rocket and the issue was resolved.
    When I tried, in a staging copy of the site, to switch back to w3 total cache, the overlay panels where accessible in the backend.
    So, I close the ticket, maybe it was just some settings which I didn’t deactivate in the first few tries.
